The Light Pull drive is a friction drive with steps 3mm, 6mm, 10mm and 16mm. Designed to help turning light pulls and similar small items with a through hole. Simply slip the blank onto the drive, bring up the tailstock with a revolving centre for support and away you go. The drive is designed to allow plenty of room to work around the light pull, including sanding and finishing. Using the Light Pull drive is a great way to use up all those small offcuts, which are too good to throw away.
Axminster Woodturning
Axminster Woodturning Light Pull Drive
| Made in Britain | Yes |
| Morse Taper | 1 MT |
| Intended Use | To help turning light pulls & similar small items with a through hole. |
| Web Attribute Set | Drive Centres |
| EAN Barcode | 5052511045785 |
