This is a replacement tip for a circular cutter for the Crown Carbide Pro Roughing Tip Turning Tool. It is a 15mm square cutter with very slightly radiused cutting edges. Manufactured from the finest quality tungsten carbide in the USA; the tips are made from the finest Nano Particle Carbide that is hardened to an unbelievable 93 HRC. This makes them ultra long lasting and, when the edge eventually dulls, all you need do is turn the cutter to a fresh sharp cutting edge.
Crown
Crown Carbide Pro Replacement Square Cutter
| Made in Britain | Yes |
| Web Attribute Set | Woodturning Tools - Individual |
