Here’s a chance to make a tool to your own design. Make a handle whatever length, diameter and shape suits you. It is not until you have made this kit you realise just how useful a small brass hammer can be. It will soon become one of your favourite tools. It is a good weight and size for all kinds of tasks.
The well machined, solid brass head provides a solid dead-blow. The head measures 32mm dia x 63mm long and weighs 625g. It is fixed to the handle with a strong internal connector bolt 1/2x 13tpi x 75mm long.
If you don't have a wood lathe for turning, you can always try the old school method and use spokeshave.
Difficulty Intermediate
Drill Bit Required 2026-02-01 00:00:00 +0000
Minimum Blank Size 25 mm x 25 mm x 140 mm
Web Attribute Set Project Kits
