A range of matching chapter rings and hands to go with our quartz clock movements. The chapter rings are either a silver or gold finish, with a 152mm diameter, with Arabic numerals, and the hands are available in a choice of designs in brass or black finish. A seconds hand is included with each set of hands; this can be discarded if not required but in this case the centre boss should be retained and used to blank off the drive shaft on the movement.
Web Attribute Set Project Kits Accessories Overall Diameter: 152 mm
EAN Barcode 5052511008537
