This is a replacement tip for a diamond shaped cutter for the Crown Carbide Pro Detail Tip Turning Tool. It has 15mm long edges with an acute angle point. Manufactured from the finest quality tungsten carbide in the USA; the tips are made from the finest Nano Particle Carbide that is hardened to an unbelievable 93 HRC. This makes them ultra long lasting and, when the edge eventually dulls, all you need do is turn the cutter to a fresh sharp cutting edge.
Made in Britain Yes
