Crown
Crown Cryo David Ellsworth Signature Bowl Gouge - 12.7mm(1/2")
SKU: 506516
€135,00
  • Almost all that is required to start and finish a bowl!
  • 1/2 gouge width
  • Cryogenic treatment for improved edge retention
Designed from tip to butt by David Ellsworth who has used his long professional experience to come up with a great performing tool that is almost all that is required to start and finish a bowl. The Ellsworth influence can be found in the cross section and length of flute, tip grind and the nicely shaped handle which gives control and balance. Hints and tips by David Ellsworth are supplied with each gouge.
Made in Britain Yes
Gouge Type Bowl Gouge Gouge Width: 12.7 mm (1/2") Web Attribute Set: Woodturning Tools - Individual
EAN Barcode 5052511088119
