Crown
Crown Cryo M42 Round Nose Scraper - 19mm(3/4")
SKU: 105913
€70,00
  • Excellent tool for refining inside of bowls and goblets
  • 19mm wide blade with well shaped ash handle
  • Made from M42 premium, high-speed steel
  • Cobalt content ensures high wear resistance
  • Tools stay sharp and hard even in heavy-duty applications
  • Cryogenically treated blades for outstanding results
  • Spend more time turning, less time sharpening
With its 19mm wide blade this round ended scraper is an excellent choice when it comes to refining the inside surface of bowls or goblets. A sharp round nose scraper is great for removing the odd smidgen to clean up the bottom of a bowl.
Turning tools made with cryogenically treated M42 cobalt HSS will give you a lifetime of good service and by their very nature ensure you spend more time at the lathe and less time at the sharpening station. The M42 steel gives you a tool with unrivalled edge retention and the ultimate tool life. M42 is a premium, high-speed steel alloy with molybdenum and 8% cobalt. One of its most significant properties is high wear resistance even on tough and abrasive timbers. The cutting edges on tools made from M42 high-speed steel stay sharp and hard even after prolonged hard usage.
Made in Britain Yes
EAN Barcode 5052511133895
