Easy Wood Tools
Easy Wood Tools Ci0-NR Carbide Cutter - Round Negative Rake
SKU: 109259
€25,00
  • Fits the Full-Size Easy Finisher and Pro Easy Finisher.
  • 15.6mm diameter, solid carbide
  • Negative rake for acrylics, resin and very hard woods
  • Optimum grade of carbide, long lasting cutting edge
  • Proprietary grinding for the sharpest edge possible
  • Precision ground finish
  • Easy Wood Tools tips are 100% made in the USA
The Ci0-NR negative rake round carbide tip is 15.6mm diameter. It fits the Full-Size Easy Finisher and Pro Easy Finisher.
Negative Rake Carbide Cutters virtually eliminate chipping and catches when turning resins, acrylic, and other man-made materials. Excellent results when turning very hard woods, and very smooth finishing cuts. Very effective for hollowing, allowing for smooth catch-free passes.
When one side of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.
