Easy Wood Tools
Easy Wood Tools Ci1-R2-NR Carbide Cutter 2" Negative Rake
SKU: 109251
€23,00
  • Fits the Full-Size Easy Rougher and Pro Easy Rougher.
  • 14.6mm square, with slightly curved edges
  • Negative rake for acrylics, resin and very hard woods
  • Optimum grade of carbide, long lasting cutting edge
  • Proprietary grinding for the sharpest edge possible
  • Precision ground finish
  • Easy Wood Tools tips are 100% made in the USA
The Ci1-R2-NR negative rake carbide tip is 14.6mm square. It fits the Full-Size Easy Rougher and Pro Easy Rougher.
Negative Rake Carbide Cutters virtually eliminate chipping and catches when turning resins, acrylic, and other man-made materials. Excellent results when turning very hard woods, and very smooth finishing cuts. Very effective for hollowing, allowing for smooth catch-free passes.
Each of the four edges is slightly curved with a radius of 2, hence the R2 suffix. The radius along the edge, minimises the risk of a catch from a sharp corner when moving the chisel from side-to-side.
When one side of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.
