The Ci2-R2 solid carbide tip is 11.1mm square. It fits the Easy Start Rougher, Mini Easy Rougher and Mid-Size Easy Rougher. Each of the four edges is slightly curved with a radius of 2
The standard carbide tips provide a neutral rake, which is the angle of a cutter relative to its cutting surface. These cutters start sharp and stay sharper longer to reduce catches and blowouts.
When one side of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.
