The Ci1-R2-NR negative rake carbide tip is 10.8mm square. It fits the Easy Start Rougher, Mini Easy Rougher and Mid-Size Easy Rougher.
Negative Rake Carbide Cutters virtually eliminate chipping and catches when turning resins, acrylic, and other man-made materials. Excellent results when turning very hard woods, and very smooth finishing cuts. Very effective for hollowing, allowing for smooth catch-free passes.
Each of the four edges is slightly curved with a radius of 2
When one side of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.
