Easy Wood Tools
Easy Wood Tools Ci4 Carbide Cutter - Diamond
SKU: 109262
€22,00
  • Fits: Easy Start Easy Detailer, Mini Easy Detailer
  • Fits: Mid-Size Easy, Full Size Easy and Pro Easy Detailers
  • 9.6mm wide, solid carbide
  • Optimum grade of carbide, long lasting cutting edge
  • Proprietary grinding for the sharpest edge possible.
  • Precision ground finish
  • Easy Wood Tools tips are 100% made in the USA
The Ci4 solid carbide diamond shaped tip is 9.6mm wide. It fits the Easy Start Easy Detailer, Mini Easy Detailer, and Mid-Size Easy Detailer, Full Size Easy Detailer and Pro Easy Detailer.
​The standard carbide cutters provide a neutral rake, which is the angle of a cutter relative to its cutting surface. These cutters start sharp and stay sharper longer to reduce catches and blowouts.
​When one portion of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.
