Easy Wood Tools
Easy Wood Tools Ci5-NR Carbide Cutter - Round Negative Rake
SKU: 109317
£20.88
£17.40 Excl. VAT
  • Fits: Micro Easy Finisher and Mini Easy Finisher
  • Fits: all Mini Easy Hollowers and all Mid-Size Easy Hollowers
  • 8.8mm diameter, solid carbide
  • Negative rake for acrylics, resin and very hard woods
  • Optimum grade of carbide, long lasting cutting edge
  • Proprietary grinding for the sharpest edge possible
  • Precision ground finish
  • Easy Wood Tools tips are 100% made in the USA
The Ci5-NR solid carbide negative rake cutter is 8.8mm diameter. It fits the Micro Easy Finisher, Mini Easy Finisher, Mini Easy Hollowers #1, #2, #3, and Mid-Size Easy Hollowers #1, #2, #3.
Negative Rake Carbide Cutters virtually eliminate chipping and catches when turning resins, acrylic, and other man-made materials. Excellent results when turning very hard woods, and very smooth finishing cuts. Very effective for hollowing, allowing for smooth catch-free passes.
When one portion of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.
