Easy Wood Tools
Easy Wood Tools Full-Size EASY ROUGHER™
SKU: 109249
€145,00
  • Ideal for spindles, large bowls, platters and other big projects
  • Rougher removes material quickly, cleanly and efficiently
  • No sharpening required - simply rotate the carbide cutter to a fresh edge
  • Solid carbide cutter keeps an edge many times longer than HSS
  • Suitable for dry or green wood, acrylics, and resin
  • 12.7mm square section bar sits flat and steady on the tool rest
  • 406mm American Maple handle, copper ferrule for strength and leverage
The Easy Wood Tools Full‑Size Easy Rougher™ is a carbide woodturning tool designed for rapid, controlled material removal when turning large spindles, table legs, big bowls, platters, and other substantial projects.
As part of the Full‑Size range, it provides maximum leverage and reach, making it ideal for handling larger, heavier workpieces with confidence and control.
Equipped with a replaceable square carbide cutter featuring a subtle 100mm corner radius, the Full‑Size Easy Rougher™ delivers smooth, predictable cutting with no sharpening required.
The substantial 12.7mm square section bar sits flat and steady on the tool rest, while the 406mm American Maple handle offers greater control during demanding roughing cuts - ideal for professional‑level or large‑scale turning.
Designed for heavy stock removal, the Full‑Size Easy Rougher™ removes material quickly, cleanly, and efficiently, helping you establish shape on large blanks with minimal effort.
When used parallel to the floor at centre height, the square bar ensures excellent tool stability and helps virtually eliminate catches and snatches, even on wide or deep workpieces.
Its geometry and mass make it perfect for tackling large diameter bowls and long spindle work before moving on to a finisher or detailer.
With no sharpening needed, simply loosen the retaining screw and rotate the cutter to a fresh edge when dull.
Easy Wood Tools’ premium solid carbide stays sharp many times longer than HSS and is suitable for turning dry or green wood, acrylics, and resin.
What you get
Square carbide cutter with slight corner radius (100mm)
Hex key for quick cutter rotation or replacement
406mm American Maple handle with copper ferrule for strength
12.7mm square section bar for maximum stability
Colour‑coded handle for quick identification within the range
Shaft engraved with carbide cutter reference number
Specifications
Overall length: 622mm
Handle length: 406mm
Bar profile: 12.7mm square
Optional upgrade
Negative rake carbide cutters are available separately and work especially well on acrylics, polyester, and resin, providing a finer, smoother surface on timber during shaping.
Replacement Tip Ci1-R4 (109303)
