Easy Wood Tools
Easy Wood Tools Lexan™ Chip Deflector - 3/8"
SKU: 109307
€35,00
  • Deflects wood chips, shavings and ribbons of resin
  • Fits the Easy Start, Mini Easy and Mid-Size Easy Wood Tools
  • Locks securely on the tool with a simple thumb-screw
This does exactly what the name implies. The Chip Deflector keeps wood chips, wood shavings and those endless ribbons of resin on the floor instead of covering your best woodturning smock. Lexan™ is a polycarbonate plastic used in cockpits and bullet-proof canopies and these Chip Deflectors. The 9.5mm (3/8) fits onto the shafts of the Easy Start, Mini Easy and Mid-Size Easy Wood Tools. The Chip Deflector locks securely on the tool’s shaft with a simple thumb-screw.
Web Attribute Set Miscellaneous Woodturning
