Easy Wood Tools
Easy Wood Tools Micro EASY DETAILER™
SKU: 109202
€98,00
  • Use for small, fine detail or delicate turning projects
  • Detailer for small coves, beads, and other fine details
  • No need to sharpen;, simply rotate cutter to a fresh edge
  • Solid carbide tip keeps an edge many, many times longer than HSS
  • Use to turn dry or green wood, acrylics and resin
  • 8mm square section bar ensures the tool sits flat and steady
  • American Maple handle with copper ferrule for strength
The Easy Wood Tools Micro Easy Detailer™ is a carbide woodturning tool designed for creating fine details, small coves, delicate beads, and precise decorative features on pens, bottle stoppers, ornaments, and miniature projects.
As part of the Micro range, it is purpose‑built for precision work in tight areas, where accuracy and control are essential.
Fitted with a diamond‑shaped replaceable carbide cutter, the Micro Easy Detailer™ allows you to cut crisp detail lines with ease. Its compact, lightweight design and flat‑profile bar ensure the tool sits securely on the rest, making it easy to control without needing to apply complex angles or techniques.
The Micro Easy Detailer™ is designed to deliver clean, accurate detailing cuts, allowing you to add definition and decoration to your work with confidence. It excels at refining small features and working in confined areas where larger tools are harder to control.
When used parallel to the floor at centre height, the flat bar design keeps the tool stable, helping reduce catches and supporting controlled, precise cuts on small‑diameter workpieces.
Easy Wood Tools’ long‑lasting carbide cutters hold an edge many times longer than HSS and are suitable for dry or green wood, as well as acrylics. With no sharpening needed, maintenance is simple — when the edge dulls, just loosen the fixing screw and rotate or replace the cutter.
The shaft is engraved with the corresponding carbide cutter reference number for easy identification.
Specifications
Tool type: Micro carbide detailing tool
Cutter type: Diamond‑shaped carbide cutter
Range: Micro (compact for ultra‑fine work)
Bar profile: Flat section for stability on the tool rest
Handle: Hardwood with copper ferrule
Negative rake carbide cutters are available separately and are particularly effective on acrylics, polyester, and resin, helping to achieve a smoother finish and increased control on delicate materials.
Replacement Tip Ci7 (109245)
EAN Barcode 5052511133338
