Easy Wood Tools
Easy Wood Tools Mid-Size EASY HOLLOWER™ #3
SKU: 109315
€165,00
  • Hollower #3 for deep‑reach interior shaping and final refinement
  • Ideal for hollow forms and medium to large bowls
  • 12.7mm square section shaft provides excellent stability
  • Solid carbide cutter lasts many times longer than HSS
  • No sharpening required - rotate the cutter to a fresh edge
  • 355mm American Maple handle, copper ferrule for strength
The Easy Wood Tools Mid‑Size Easy Hollower™ #3 is a carbide woodturning tool designed for final interior shaping and deep‑reach hollowing inside hollow forms and medium to large bowls.
As the third tool in the Hollowing 1‑2‑3 system, Hollower #3 reaches deep, unseen cavities, allowing you to refine the final internal surface once Hollower #1 and #2 have established the interior shape.
Featuring a solid carbide cutting tip and a 12.7mm square section shaft, the Mid‑Size Easy Hollower™ #3 sits flat and stable on your tool rest, delivering excellent control with no sharpening required.
The longer 355mm American Maple handle offers added leverage for deep interior cuts, while the tool’s cutter orientation and reach provide safe, predictable cutting inside areas where visibility is limited.
Hollower #3 is engineered for deep hollowing and final refinement, allowing you to smooth and finish the interior walls of hollow forms with precision.
Used parallel to the floor at centre height, the square shaft keeps the tool steady on the rest, helping to minimise catches and snatches, especially when working deep inside closed forms.
It provides the reach and finesse needed for the last stage of hollowing, before sanding or final surface work.
With no sharpening required, simply loosen the fixing screw and rotate the cutter to a fresh edge when it eventually dulls.
Easy Wood Tools’ premium carbide lasts many times longer than HSS and can be used on dry or green wood and acrylics.
What you get
Solid carbide cutter fitted as standard
355mm American Maple handle with copper ferrule for strength
12.7mm square section shaft for maximum stability on the rest
Colour‑coded handle for quick identification within the 1‑2‑3 system
Engraved carbide cutter reference number on the shaft
Specifications
Overall length: 572mm
Handle length: 355mm
Shaft profile: 12.7mm square
Optional upgrade
Negative rake carbide cutters are available separately and work especially well on acrylics, polyester, and resin, while delivering a finer, smoother finish on timber during deep interior shaping.
Replacement Tip Ci5 (109316)
