Easy Wood Tools
Easy Wood Tools Pi160-NR Negative Rake Carbide Replacement Blade
SKU: 109323
€39,00
  • Fits: Easy Wood Easy Parting Tool
  • 3.2mm wide, solid carbide tip
  • Permanently fixed in a stainless steel blade
  • Optimum grade of carbide, long lasting cutting edge
  • Proprietary grinding for the sharpest edge possible.
  • Precision ground finish
  • Easy Wood Tools tips are 100% made in the USA
The Ci160 parting tool tip is 3.2mm wide. The tip is permanently fixed to a stainless steel blade. This assembly fits the Easy Wood Tools Parting Tool.
The tip is precision ground with a negative rake. Negative Rake Carbide Cutters perform particularly well in all timbers and are preferred when turning resins, acrylic, and other man-made materials
