Perform
Perform TCT Diamond Blade (Pkt 2)
SKU: 113578
€8,95
  • Fits Perform Replaceable Tip Turning Tool Set
  • 10 x 28mm diamond blade
  • Tungsten carbide stays sharp longer
  • Rotate tip for fresh edge - no sharpening
  • Supplied as a convenient 2 pack
Designed for the Perform Replaceable Tip Turning Tool Set, this 10 x 28mm TCT diamond blade is great for fine detail work, tight corners and creating beads. Simply screw it onto your turning tool. Made from durable tungsten carbide, it stays sharper longer than traditional turning tools, offering extended tool life and consistent performance.
When the edge dulls, simply rotate to a fresh cutting edge on your turning tool. Once all four edges are used, replace the tip - no sharpening required.
Supplied as a 2 pack.
EAN Barcode 5052511143146
