Cascamite
Cascamite Powdered Resin Wood Glue
SKU: 400023
€27,00
  • Powdered Resin with gap filling properties and clear glue line
  • Interior/Exterior use non -taining and mould resistant
  • Fast bond strength, tack time 1-2hrs, cure time 6 hours approximately
Cascamite (also known as Polymite) is a very well respected adhesive in the trade, especially formulated for exterior joinery that will be exposed to the weather. A synthetic resin, it is weatherproof when dry, sold as a powder it is mixed with water before use and has good gap filling properties, suitable for load bearing and laminating. Leaves a clear glue line and will not discolour hardwood, mould resistant. Tack time 1-2 hours cure time 6 hours (temperature dependent) An excellent well proven adhesive for joinery, cabinet work or boat building.
Setting Time 6 hours
Suitable For Wood MDF
Adhesive Type Powdered Resin
Pack Size 1.5 kg
Web Attribute Set Resin Adhesives
