Formulated from the Original Wood Glue this professional interior aliphatic resin emulsion will give you the same reliability of bond and more. Providing you with more 'open time' for complicated assemblies and the extended application times needed for laminations. Developing a bond stronger than the wood itself, Extend Wood Glue is also stiffer and more heat resistant in the fully cured state than Titebond III and most other PVA and aliphatic resins, making it most suitable for laminations in shaped work and interior applications likely to be exposed to higher than normal temperatures (kitchens, fire surrounds, radiator covers, trivets, airing cupboards to name but a few).
Titebond
Titebond Extend Wood Glue
| Setting Time | 24hrs without stress |
| Suitable For | Wood Cloth Leather MDF |
| Clean Up | Water |
| Adhesive Type | Aliphatic Resin |
| Available Sizes | 473 ml (16 fl.oz) |
| Web Attribute Set | General Woodworking Adhesives |
| EAN Barcode | 37083091045 |
