CorePlus Diamond Tile Drill Bit 8mm
113384
From £14.81 £12.34
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Friday 11th Jul
  • Online exclusive
  • Achieve precise cuts on porcelain and ceramic tiles with ease
  • Diamonds stay bonded for an extremely long life
  • Premium-grade, braze-bonded diamonds cut through the hardest materials effortlessly
  • Allows you to start drilling without additional guides
  • Operates efficiently with minimal water cooling
  • Eliminates the need for a continuous water feed
  • Allows for continuous hole cutting by automatically ejecting core waste material
  • Ensures excellent performance on cordless drills, providing stability and precision
The CorePlus Diamond Tile Drill Bit 8mm is a top-tier tool designed for professionals and DIY enthusiasts alike. This drill bit is engineered to deliver fast, clean cuts on both porcelain and ceramic tiles, making it an essential addition to your toolkit.
It features leading-edge vacuum brazing technology, which ensures the diamonds stay bonded for an extremely long life. The premium-grade, braze-bonded diamonds are designed to cut through the hardest materials effortlessly.
This drill bit simplifies the drilling process, allowing you to start drilling without additional guides. It operates efficiently with minimal water cooling, eliminating the need for a continuous water feed. Additionally, it allows for continuous hole cutting by automatically ejecting core waste material. The Tri-Flat shank ensures excellent performance on cordless drills, providing stability and precision. With these features, the CorePlus Diamond Tile Drill Bit 8mm stands out as a reliable and efficient tool for all your tile drilling needs.
