N.B. Each kit is supplied as the components only and does not include the material/blank. Make time with these kits. Whether as a gift or for personal use, we guarantee they will give hours of pleasure. These fascinating Skeleton Clock Movements feature a clear front and rear allowing you to watch the workings of the clock in real time. The outer chapter ring and decorative hands display the hours and minutes. Just above the figure six, a second dial ticks off the seconds. An accurate quartz movement drives the exposed inner workings making a very attractive clock. The skeleton clock comes fully assembled and ready to mount in a frame or base of your making. A glass front protects the face of the clock; the plated bezel has an overall diameter of 103mm. The main body of the clock is a push fit into a hole approximately 94mm. The clock comes with a toothed rubber band for a secure fit. Requires one AAA battery (not supplied).
Axminster Woodturning
100mm Silver Skeleton Clock Insert
| Batteries | Requires 1 x AAA |
| Battery Type | Alkaline |
| Difficulty | Beginner |
| EAN Barcode | 5052511094592 |
