N.B. Each kit is supplied as the components only and does not include the material/blank.
Make time with these kits. Whether as a gift or for personal use, we guarantee they will give hours of pleasure. These fascinating Skeleton Clock Movements feature a clear front and rear allowing you to watch the workings of the clock in real time.
The outer chapter ring and decorative hands display the hours and minutes. Just above the figure six, a second dial ticks off the seconds. An accurate quartz movement drives the exposed inner workings making a very attractive clock. The skeleton clock comes fully assembled and ready to mount in a frame or base of your making.
A glass front protects the face of the clock; the plated bezel has an overall diameter of 103mm. The main body of the clock is a push fit into a hole approximately 94mm. The clock comes with a toothed rubber band for a secure fit. Requires one AAA battery (not supplied).
Please enable "Performance Cookies" for our best Reviews and Q&A experience. To change your cookie preferences please see our Cookie Policy.
Rated 5 out of
5 by
Stevei from
Good looking Skeleton ClockFitted the Skeleton Clock into the Ash Wood Frame.
Date published: 2022-11-29
Rated 4 out of
5 by
Shed guitars from
Cheap, good looking but flawed.This is a nice looking clock. Cheap as chips and works well. The only drawback is that you can’t easily tell the time if you are more than ten foot away or in bad light. I had read this in previous reviews but dismissed them thinking “ how bad can they be “. Unfortunately, they were right, it is quite tricky to tell the time at first look.
Date published: 2022-07-26
Rated 5 out of
5 by
billb88 from
a very smart looking clockI had a nice piece of oak and set the clock into it it looks very smart and have a happy wife
Date published: 2022-07-22
Rated 5 out of
5 by
bunny from
good clockbought this to make a clock for a friend and he was very happy
Date published: 2022-02-03
Rated 5 out of
5 by
Why Why Why from
Great Value. Looks GreatWorks well. Looks good. Because I’m required to submit a certain amount of words for this review I’ve decided that I’ll add the fact that this item spookily does what it says on the box. It tells the time and looks good. Would I buy another, yes I would. Why I’m required to submit a nickname is beyond me.
Date published: 2021-12-07
Rated 5 out of
5 by
MatD from
Great unit, needs more accurate descriptionThis was perfect for my project using scrap from work. Clear back with moving gears. The second hand on the small face does tick, but is not overly loud. Comes with a rubber gasket that will conform to small variances when mounting, and allows it to be easily removed for changing the single AA battery. Bezel rotates clockwise to be removed. I will include exact dimensions as they would have been helpful to have in the description. My opening was 99.4mm and the gasket was not large enough. I wrapped the body in electrical tape until the desired fit was achieved (1mm of compression on the gasket was perfect).
Outer Diameter (OD) of bezel: 103mm, OD of gasket (no compression): 97mm, OD of body at face: 91mm, OD of body at back: 89mm, depth from back of bezel to back of battery compartment: 38.6mm, OD of body flange for bezel mount: 98.8mm, bezel thickness 11.2mm
Date published: 2021-04-30
Rated 5 out of
5 by
Aircooled from
GreatLovely bit of kit. The skeleton style adds a bit of a different dimension. Nice one thanks
Date published: 2021-01-26
Rated 5 out of
5 by
ACT1943 from
Always popular at Craft FairsI enjoy using the skeleton clocks and they always attract a lot of interest
