Executive Pen Kits
- A classic design with simple lines
- Available either as a fountain pen or rollerball
- Use timber or acrylics to produce you own unique pens
- 22mm blank required
- 37/64" and 15/32" Drill bits required
Micro-Mesh Soft Touch Abrasive Pads 50 x 50mm - Mixed (Pkt 9)From £15.58 £12.98
A fine classic design of pen available either as a fountain pen or rollerball. The Executive would make a great gift either individually or as a pair. With a gold finish and a raised silver ring around the centre band, the simple uncluttered lines of this pen will make a classy gift. Use timber or acrylic to produce your own unique designs.
A blank of at least 22mm square will be required to make these pens. 37/64" and 15/32" drill bits required. When using a mandrel to make these pens, bushing set 502691 will be required.
Bushing Set Order No. | 502691 |
Difficulty | Beginner |
Drill Bit Required | 15/32" and 37/64" |
Minimum Blank Size | 22 mm x 22 mm x 140 mm |
