Twist Pen Kits
Twist Pen Kits
- Nickel Satin finish twist pen
- Bushing set not required
- 7mm drill bit required
A very popular classic writing instrument, in a nickel satin finish, with a standard twist mechanism. If a mandrel is used to make these pens no bushings are necessary and a 7mm drill will be required. We recommend the Fisch pen drill (502103) which is available in this size. For ink refills order 310492.
Bushing Set Order No. | 8.5mm O/D (as supplied with mandrel) (100793) |
Difficulty | Beginner |
Drill Bit Required | 7 mm |
Minimum Blank Size | 16 mm x 16 mm x 112 mm |
Pen Type | Twist Pen |
Refill Order Number | 310492 |
