UJK
UJK ER Collets
SKU: 112195
£10.58
£8.82 Excl. VAT
  • Engineering style ER collets for precision woodworking collets
  • Engineered to hold tools with exceptional precision
  • Minimises runout for a centred and secure hold
  • Designed for accuracy and reliability
  • Ideal for modern routing setups, providing a firmer grip on cutter shanks
  • Available in 8mm, 12mm, 1/4, and 1/2
Precision woodworking deserves precision tooling. The UJK Parallel Action Collets are manufactured to bring the accuracy of engineering clamping into the woodworking environment. These collets are meticulously engineered to hold tools with exceptional precision, significantly enhancing the accuracy, efficiency, and safety when routing.
UJK Parallel Action Collets are designed with multi-split parallel action, minimising vibration by gripping the entire length of the collet. The precision ground design ensures that tools are held accurately with evenly distributed force, providing a consistent and reliable grip while preventing tool slippage.
Parallel action collets are known for their unique profile and multiple slits, offering a wide clamping range with a slight taper that compresses onto the tool when the collet nut is tightened. These collets ensure a centred and secure hold, minimising any potential runout and providing a firmer grip on cutter shanks to help the cutter run truer.
Available in four sizes: 8mm, 12mm, 1/4, and 1/2, the UJK ER Collets are perfect for any woodworking task that demands precision and reliability.
Compatible with:
LU - MOF77, MOF98, MOF131, MOF177
DEWALT - DW625, DW626, DWE625
TREND - T8, T10, T11, T12, T14
CMT - CMT1E
FESTOOL - OF1400, OF2000, OF2200
FREUD - FT1700, FT2000, FT2030, FT2200, FT3000
METABO - OFE1812
Web Attribute Set Router Collet & Cutter Care
EAN Barcode 5052511139033
