The DeWALT® Box Beam Level delivers high accuracy and durability, making it suitable for demanding professional use. Its robust design features a large cross-section reinforced with metal construction and durable overmoulded end caps for enhanced protection on site.
Equipped with solid block vials, including 2 vertical and 1 horizontal vial, this level ensures versatile and precise measurements. The die-cast centre vial holder maintains consistent accuracy even under tough working conditions, while the magnified centre vial improves visibility for easier reading.
Additional design features such as carry hand holes and dual hang holes provide convenient handling, transport, and storage. The bridged centre vial construction enhances body rigidity and allows for a continuous working edge, while dual milled surfaces ensure dependable accuracy across two faces.
Level Length 600 mm (24)
Web Attribute Set Levels
EAN Barcode 3253560432249
Accessories
  • Stabila 70TMW Torpedo Level 26cm Magnetic Base & Rotatable Angle Vial
  • Hultafors BM8M Brick-Mate Pocket Tape 8m (Width 25mm) (Metric Only)
  • Hultafors Dry Marker Hultafors Dry Marker
    £8.50 £11.40 Save £2.90
