A router can be used for many tasks and this kit gives even more versatility, supplied with 2 bases, plunge or fixed that can be easily swapped over making it 2 routers in one covering many applications. Very compact and solidly built this machine handles well and is easily controlled whichever base you are using. The powerful variable speed 900W motor has full wave electronics to ensure the selected speed is maintained under any load for the best finish and there is a spindle lock for ease of cutter change. Each base fits to the motor body with a quick lever. The plunge base has precise depth adjustment and a five position adjustable turret for stepped/repeated plunge cuts, moulded handles ensure a positive grip. The fixed base has a wide depth ring collar that moves up and down the scroll in the motor body allowing for depth setting, fine adjustment is made with a thinner calibrated ring. The machine is supplied with a kit of accessories including: This machine is supplied with two fences, a fixed base fence and the plunge base fence, 2 dust extraction adaptors, 1/4 collet, centring cone, 17mm guide bush, collet spanner and storage case. N.B. Optional 8mm collet available.
Collets Supplied 2026-04-01 00:00:00 +0100
Rating Trade/Professional
Spindle Lock Standard Feature
Sound Power Level LwA [Uncertainty K] 88 dB(A) [2.8 dB]
Corded or Cordless Corded
Sound Pressure Level LpA [Uncertainty K] 77 dB(A) [2.8 dB]
Vibration Cutting Wood [Uncertainty K] 6.8 m/s² [2.7 m/s²]
Motor Power 900 W
Plug Fitted UK 3 pin plug
Cutter Speed 16,000 - 27,000 rpm
Voltage 230 V
Web Attribute Set Routers
EAN Barcode 5035048315767
