Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 3-5 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
DeWALT DHS780T2 XR FLEXVOLT 305mm Mitre Saw 2 x 54V Batteries
Code: 104208
  • Online exclusive
  • Large capacity in both crosscutting and vertical applications
  • 54V battery power for exceptional performance
  • Optional mains adaptor
  • Positive mitre stops; left and right at common angles
  • Up to 49° bevel cuts both left and right
  • XPS Shadow Line cut system for accurate, repeatable alignment
  • Twin rails and bronze bushes for consistent long term rigidity
  • Dual sliding fence ensures full support for large workpieces
  • Exceptional dust control and chip deflection
  • Adjustable stop allows trenching, grooving and rebating
  • Supplied with 2 x DCB546 54V/18V (6.0Ah/2.0Ah) FLEXVOLT batteries, charger, dust bag and 60-tooth TCT blade
  • Show More
£1,079.96 (£899.97 Ex. VAT)
Out of stock
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We'll aim to despatch your products the same day when you order before 3pm, Monday to Friday.
  • Standard UK (3-5 day) - free
  • Premium UK (next day) - from £6
  • International - available
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
DeWALT 3 Year Warranty (Registration Required)
DeWALT XR FLEXVOLT range of 54V cordless power tools offers unrivalled runtimes and performance. Professionals can now reliably undertake seriously heavy duty construction work in situations where mains power is unavailable.
The DHS780T2 XR FLEXVOLT mitre saw provides you with all the benefits and performance of a mains powered saw in a portable, cordless power tool. An optional AC mains adaptor is available for situations requiring long, continuous runtimes.
The precision machined base and fence ensure consistent accuracy. The base has integrated positive stops at common angles with a maximum mitre capability of 60° left and 50° right. A quick release bevel stop setting provides accurate setting the of bevel angle up to 49° both left and right. The top portions of the high rear fence slide ensure maximum support when cutting large workpieces at any angle or combination of angles. The head runs on twin bars; bronze bushes ensure smooth operation and long term rigidity even when cutting at the 345 mm maximum. You can adjust the depth of cut, enabling the saw to trench or cut rebates.
A built-in LED work light illuminates the workpiece for improved sighting even in bright conditions. DeWALT XPS Shadow Line cut technology provides a clear cut-indicator for fast and accurate alignment of the cutting line.
The DHS780T2 comes fitted with a 305mm thin kerf 60-tooth TCT blade, 2 x 54V (6.0Ah) batteries and charger, dust bag and material clamp.
N.B. the first cut with the saw will cut into a black cover underneath the yellow blade strips, it is not the base. This is the blade contacting the GUARD TROUGH and not the base. The reason for this is for shipment, if the unit is dropped, the blade cannot hit the wear ring. The fit is a packing and with the first cut, the material will be removed, and is planned this way.
Promo
Specification
Specification
Batteries Included 2
Battery Capacity 6.0 Ah
Battery Type Li-ion
Battery Voltage 54 V
Bevel Angle Range 49° - 0 - 49°
Blade Diameter 305 mm
Bore Size 30 mm
Mitre Angle Range 50° - 0 - 60°
Model DHS780T2
Nett Weight 25.5 kg
Overall L x W x H 470 mm x 770 mm x 396 mm
Rating Industrial
Sound Power Level [Uncertainty K] 100 dB(A) [3.9 dB]
Sound Pressure Level [Uncertainty K] 93 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] <2.5 m/s² [1.5 m/s²]
Max Bevel Cut @ 45º W x H 268 mm x 63 mm or 345 mm x 44 mm
Max Compound Cut @ 45º W x H 212 mm x 76 mm
Max Crosscut @ 0º W x H 345 mm x 76 mm or 303 mm x 110 mm
Max Mitre Cut @ 45º W x H 244 mm x 76 mm or 211 mm x 112 mm
Blade RPM 1,900 - 3,800 rpm
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
