DeWALT DT70619T Impact Rated Right Angle Attachment
- Suitable for use with impact drivers and cordless drills
- Perfect for screwdriving in tight corners and narrow gaps
- Screw retaining magnet around the screwdriving tip
Customers Also Bought
A right angle drill attachment that is as neat and compact as you would wish. From the DeWALT Extreme range, it is suitable for use with impact drivers and cordless drills and accepts standard 1/4" hex shank bits. The DeWALT DT70619T Right Angle Impact Screwdriving Attachment is sturdy, durable, well designed and perfect for driving screws in tight corners, narrow gaps and at awkward angles.
Designed for use with 25mm long bits, it comes with 8 Impact Torsion Bits: 2x Ph2, 2x Pz2, T10, T15, T20 and T25. The DT70619T features a small ring magnet around the screwdriving tip, which retains the screw head on the tip.
Overall length 150mm, only 45mm deep by 32mm wide, tip centre to top edge 15mm.
- Only 45mm deep x 32mm wide, tip centre to top edge 15mm
- Accepts standard 1/4" hex shank bits
- Supplied with 8 Impact Torsion Bits: 2x Ph2, 2x Pz2, T10, T15, T20 and T25
- Overall length 150mm
