Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 3-5 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
DeWALT DW717XPS 250mm Mitre Saw & DE7023 Stand
  • DeWALT DW717XPS Mitre Saw
  • Compact and portable with large cutting capacity
  • XPS shadow line cut indicator for accurate alignment with the cut line
  • Grooving stop for trenching or rebating
  • Cam action mitre lock function for angles 60°L and 50°R
  • Quick release setting of bevel angles up to 48°L and R
  • Dual sliding fence gives plenty of support for tall workpieces
  • DeWALT DE7023 Mitre Saw Stand
  • Accommodates all DeWALT mitre saws
  • Lightweight aluminium construction provides portability
  • 1.7m beam extends to support up to 3.9m and can support up to 182kg
  • Work stops convert into end stops for repeat cutting
  • Integral folding legs and carry handle
  • Show More
£744.96 (£620.80 Ex. VAT)
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
DeWALT 3 Year Warranty (Registration Required)
Package deal comprises the DeWALT DW717XPS Mitre Saw and the DeWALT DE7023 Mitre Saw Stand
Whether cutting mitres, bevels or a combination of both, the DW717XPS is quick and easy to set giving you perfect results every time. The machine features a cam-action mitre lock function for angles between 0° - 60° left and 0° - 50° right and a quick release setting of bevel angles up to 48° left and right. The powerful motor and 250mm diameter blade result in a compact and portable mitre saw with plenty of cutting capacity. The horizontal rails run in bronze guides, which provide maximum support for precision cutting up to 320mm wide. The large dual sliding fence gives plenty of support for tall workpieces at any angle providing stability and accuracy. DeWALT’s unique XPS shadow line cut indicator gives you a fast and accurate way to align the blade with the cut line, at the same time the LED illuminates the work. A grooving stop allows you to carry out trenching or rebating.
Supplied with TCT tooth blade, blade spanner, dust bag and material clamp
A lightweight aluminium construction provides portability in and around the job site and accommodates all DeWALT mitre saws. The 1.7m beam extends to support up to 3.9m for use with large workpieces and can support up to 182kg providing maximum flexibility and capacity. The work stops convert into end stops for repetitive cutting to length. The integral folding legs avoid unnecessary assembly and the integrated carry handle provides easy transportation.
Specification
Specification
Bevel Angle Range 48° - 0 - 48°
Blade Diameter 250 mm
Bore Size 30 mm
Dust Collection Dust Bag Supplied
Electric Brake Standard Feature
Mitre Angle Range 60° - 0 - 50°
Model DW717XPS + DE7023
Motor Power 1,675 W
Nett Weight 23 kg
Overall L x W x H 718 mm x 541 mm x 442 mm
Rating Trade
Sound Power Level [Uncertainty K] 99 dB(A) [3.0 dB]
Sound Pressure Level [Uncertainty K] 91 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] 2.3 m/s² [1.5 m/s²]
Max Bevel Cut @ 45º W x H 320 mm x 50 mm or 302 mm x 58 mm
Max Compound Cut @ 45º W x H 226 mm x 50 mm
Max Crosscut @ 0º W x H 320 mm x 76 mm or 302 mm x 88 mm
Max Mitre Cut @ 45º W x H 226 mm x 76 mm or 213 mm x 88 mm
Blade RPM 4,000 rpm
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
