Spread the cost of orders up to £15,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £15,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
The DeWALT 733 Thicknesser has a powerful 1,800W motor designed for heavy duty thicknessing. The machine is reasonably compact and weighs a little over 33kg so transporting it from job site to job site is feasible. In a small workshop it will be invaluable. Holes in the base enable you to bolt the machine onto a workbench. The large infeed and outfeed tables provide plenty of support and are easily adjustable for a snipe-free finish. The cutter head is supported on four columns offering smooth and accurate movement. The thickness scale is clear and easy to read and can be recalibrated if need be. The crank handle is graduated making small adjustments quick and easy. At the front of the machine is a material removal gauge which tells you how much material your 'pass' will remove before you press the start button. The lever operated head-lock eliminates any movement in the cutter head, ensuring a better surface finish.
With a feed rate of 8m/min and a 2-knife cutter block rotating 10,000 times per minute a fine finish is guaranteed. The machine is capable of planing from 152m down to a thickness of 3.2mm. The DeWALT 733 comes with a dust extraction hood, connection to a suitable extractor will be found to be of great benefit. This is an efficient and accurate machine.
Supplied with: dust shroud and adapter, hex key, blade spanner and blade setting guides.
The product must be registered by the original DEWALT Product user within 4 Weeks of Purchase by visiting the DEWALT website (DEWALT Product user contact details, tool catalogue number, serial number and date code required). Kits comprising a range of tools are excluded from registration, but individual tools from kits must be registered.
In order to make a claim, you will need to submit proof of purchase to us or an authorised DEWALT repair agent, and the product must display the CE mark.
