Diamond Sharpening Stones
  • Rider Double-Sided Diamond Bench Stone Rider Double-Sided Diamond Bench Stone
  • Axminster Diamond Pocket Sharpener Axminster Diamond Pocket Sharpener
    Out of Stock
    £3.98
  • Axminster Double-Sided Folding Diamond Sharpener Axminster Double-Sided Folding Diamond Sharpener
  • Axminster Four Grit Diamond Hone Axminster Four Grit Diamond Hone
    Out of Stock
    £5.98
  • Axminster Diamond Sharpener Axminster Diamond Sharpener
    Out of Stock
    £5.98
  • Axminster Diamond Sheets Axminster Diamond Sheets
    Out of Stock
    £13.98
    This selects the Grit of the variant Grit
  • Tormek DF-250 Diamond Wheel Fine - 250mm
  • Tormek DC-250 Diamond Wheel Coarse - 250mm
  • Tormek DE-250 Diamond Wheel Extra Fine - 250mm
  • Shokunin Atoma Self-Adhesive Diamond Sheet Shokunin Atoma Self-Adhesive Diamond Sheet
    Out of Stock
    £40.38 - £46.88
  • Tormek DC-200 Diamond Wheel Coarse - 200mm Tormek DC-200 Diamond Wheel Coarse - 200mm
  • Tormek DF-200 Diamond Wheel Fine - 200mm Tormek DF-200 Diamond Wheel Fine - 200mm
  • Tormek DE-200 Diamond Wheel Extra Fine - 200mm Tormek DE-200 Diamond Wheel Extra Fine - 200mm
  • Faithfull Triangular Diamond Sharpening Stone Faithfull Triangular Diamond Sharpening Stone
Diamond sharpening stones provide fast, consistent sharpening for chisels, plane irons, carving tools, knives and other cutting tools. Featuring an industrial diamond abrasive surface, they cut quickly, remain flat in use and require minimal maintenance, making them ideal for woodworking, carving and workshop sharpening. Available in a range of grits for coarse grinding through to fine honing, diamond sharpening stones help keep edges sharp and performing at their best. Browse the range to find the right diamond sharpening stone for your sharpening routine.
