DMT Dia-Sharp Diamond Mini-Hones
- Carefully graded mono-crystalline diamonds
- 63.5mm x 19mm continuous diamond surface
- Overall length is 180mm, tip only 0.85mm thick
DMT Mini-Hones have 63.5 x 19mm of continuous diamond hone permanently bonded to a comfortable, colour coded handle for easy identification. The Mini-Hones have a protruding tip just 0.85mm thick for getting into tight corners. These are amongst the handiest sharpening tools money can buy, with hundreds of uses from sharpening small scissors and touching up router cutters to de-burring. Available individually or make a saving on the set of three, Coarse (blue) 325g, Fine (red) 600g and Extra Fine (green) 1,200g.
Overall L x W x H | 178 mm x 19 mm x 5 mm |
