Door Mate 8-in-1 Multi-Tool
- Save time when hanging doors, fitting locks and hinges
- Multi-function tool makes the job easier and quicker
- Multi problem solver packed into one neat tool
- No more repeat setting of a combination square
- Tough, injection moulded nylon
This ingenious marking tool is a real time saver when it comes to hanging doors, fitting locks and hinges. Good things come in small packages and this brilliant little 8 in 1 tool is no exception. The multiple functions save the repeat setting and resetting your combination square and then some.
When it comes to fitting a door, here’s what this tough, nylon injection moulded tool can do:
Mark the centreline of 35, 44 and 54mm doors for the fast positioning of locks and latches.
Mini square when marking doors for spindle or cylinder centres.
Integral mini ruler for quick and accurate marking
Dust collector when drilling for fixing brackets or fixtures.
Gauge a 3mm door gap for fire door installation and inspection.
5mm and 7mm architrave marker
32mm centre marker for System 32 cabinet hinges etc.
Provide a simple rounded shelving template for sharp edge removal.
Centre finder for standard 44mm timber for the fast marking out of halving/ lap joints.
All this in a tool only 100mm x 110mm x 40mm, a multi problem solver in a small space, a useful addition to the tool box.
