Dremel 4000JR 4/65 Multi-Tool with 65 Accessories
- Very controllable and powerful 175W Multi-Tool
- Electronic feedback with fully variable constant speed
- Variable 5,000-35,000rpm with separate on/off switch
Customers Also Bought
For more intense work, the high power 175W 4000 Series Dremel has to be one of the most controllable speed rotary multi-tools, with a separate on/off switch and electronic feedback mechanism that ensures the speed remains at the set level and does not drop off dramatically, as soon as the load is applied. The variable speed (5,000-35,000rpm) allows for sanding operations at the lower speeds and the use of very fine grinding points at the higher speed. Soft start and 2 nose pieces with soft grip for comfort, especially useful for control and when working in close confines on delicate materials. This really is an all-round kit. Supplied in a storage case with with 65 accessories plus four additional attachments: long Flex Shaft with hand piece, detailers handle for extra guidance, shaping platform for sanding etc & line and circle guide with cutter and a 3.2mm collet.
2 year warranty.
- 65 accessories included
- 4 attachments, Flexishaft, Precision handle, 3.2mm collet
- Sanding platform and Line and circle guide with cutter
- Choice of 2 nose pieces for comfort grip, storage case
- 2 year warranty
