FlexiSander Dual-Grit Sanding Pads (Pkt 3)
- Double-sided with flexible foam core
- Suitable for work on both flat and curved surfaces
- Ideal for model making, craft and small DIY tasks
- Long life abrasive, use wet or dry
- Coarse (60/100), Medium (240/400), Fine (600/1000)
Axcaliber 12 Piece 1/4" (6.35mm) Long Shank Cutter SetSpecial Price £69.97 £58.31 was £89.98 £74.98 Save £20.01 £16.67
These sanding pads feature a flexible foam core with a different grit abrasive on each side. There are 3 pads in each pack giving you 6 grades from a coarse 60 grit to a very fine 1,000 grit. The shape and size allows you to reach into awkward areas for detail work a well as working on flat or contoured surfaces.
You can use these pads either wet or dry. Hard wearing, you can wash them and use them many times over. They are excellent for polishing out scratches, paint surface preparation on metals, woods and plastics. In addition, they are perfect for cleaning, de-rusting, de-burring, burnishing, erasing and controlled material removal.
The grits are 60/100, 240/400 and 600/1000; available in slim for detail work or wide for general model finishing.
Abrasive Backing | Foam |
