Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 3-5 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Dura-Grit CS4 Carbide Shaping & Cutting Wheel - 32mm
Code: 104804
  • Shape, groove, create bevels or hollow with the same wheel
  • Cuts, shapes and finishes in one operation
  • Can be used on a wide variety of materials
  • Fits all Dremel, Proxxon and other small drill grinders
  • Diameter 32mm
  • Maximum cutting depth 13mm
  • Grit grade 60, permanently bonded
  • Mounted on an extra strong, steel mandrel 1/8" (3mm)
  • Show More
£18.85 (£15.71 Ex. VAT)
In stock - get it tomorrow, Friday 5th Jun, order within and choose Premium delivery
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We'll aim to despatch your products the same day when you order before 4pm, Monday to Friday.
  • Standard UK (3-5 day) - £2.95
  • Premium UK (next day) - from £6
  • International - available
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
  • Dura-Grit CS4 Carbide Shaping & Cutting Wheel - 32mm
  • Dura-Grit Carbide Mushroom Shaping Wheel
  • Axminster Tools & Machinery Catalogue 2019/20
Total: £37.65
Description
In Detail
With coarse 60 grit carbide on both its edge and on its face, it removes material rapidly, leaving a reasonable smooth finish. The 32mm diameter Dura-Grit CS4 is a strong and durable steel wheel, with aggressive 60-grit carbide on both its edge and on its face. Mandrel is 1/8" (3mm). You can use edge of the CS4 wheel to cut a wide variety of materials to a depth of 13mm. By using the face of the CS4, you can shape, groove, create bevels or hollows etc, all with the same tool.
Excellent for DIY, woodworking, power carving, modelling, hobby and craft projects, Dura-Grit are powerful, long lasting cutting and shaping tools that finish as they cut. Swiss machined, they are ideal for use on hard and soft woods, fibreglass, composites, carbon fibre, laminates, rigid and flex PVC piping, rubber hose, ABS and PVC plastics. The tungsten-carbide grit remains sharp for an extended life and won't tear loose.
Exhaustive testings repeatedly show Dura-Grit tools outlasting sandpaper hundreds of times. These tools need little cleaning, however, residue can be removed by running the tip into the bristles of a wire/stainless brush or into uncured rubber. Any of the burr tips can be unscrewed from the mandrel and fibre washer and soaked in solvent (Acetone), or burned clean with a propane torch without damage. Cleaning the burr will restore the cutting surface to virtually new and extend the working life of the tool.
Promo
This product is on page 386 of the Axminster Tools & Machinery 2019/20 Catalogue.
Specification
Specification
Model CS4
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
