Easy Wood Tools Ci2-SQ Carbide Cutter Square
109254
From £13.98 £11.65
2 Reviews
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Thursday 15th May
  • Fits the Easy Start, Mini Easy and Mid-Size Easy Roughers
  • 10.8mm square, solid carbide
  • Optimum grade of carbide, long lasting cutting edge
  • Proprietary grinding for the sharpest edge possible.
  • Precision ground finish
  • Easy Wood Tools tips are 100% made in the USA
  1. Easy Wood Tools Ci2-SQ Carbide Cutter Square
Total:
£41.02 £34.18
The Ci2 solid carbide tip is 10.8mm square. It fits the Easy Start Rougher, Mini Easy Rougher and Mid-Size Easy Rougher.
​The standard carbide tips provide a neutral rake, which is the angle of a cutter relative to its cutting surface. These cutters start sharp and stay sharper longer to reduce catches and blowouts.
​When one side of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.
5.00 2
