More deals added in
Have you clocked our Christmas Countdown deals?
From £18.78 £15.65
Low Stock
- get it Friday 8th Dec, order within and choose Premium delivery. Delivery info
  • Fits: Easy Start Easy Detailer, Mini Easy Detailer
  • Fits: Mid-Size Easy, Full Size Easy and Pro Easy Detailers
  • 9.6mm wide, solid carbide
Customers Also Bought
Easy to turn. Easy to own.
100% Made in America
Easy Wood Tools were the first company to develop replaceable carbide-tipped turning tools for professional woodturners and hobbyists back in 2008. The company makes the tools in their headquarters in Kentucky and the carbide tips in their own manufacturing plant in Illinois. This gives them complete control over development and quality of their products.
What makes them 'Easy'?
Square section bar
This unique design ensures the tool sits flat and steady on the tool rest, making it safer and easier to use. No need to learn specific bevels or cutting angles to make your cuts, simply hold the tool and move it left or right to rough out, smooth or create coves or beads.
No need to sharpen
Each tool features a carbide cutter which keeps an edge at least ten times longer than HSS (High Speed Steel). When an edge eventually becomes dull, simply slacken the fixing screw, turn to a fresh edge and go again.
Pick your project
Easy Wood Tools offer a range of different size tools to ensure you have a tool perfect for your project. Within each range the tools have different coloured handles for quick and easy recognition.
Use these tools to turn dry or green wood; they equally work well on very hard woods, acrylics and resins. The negative rake tips work particularly well on acrylics, polyester and resins, and produce a smooth finish on timber.
  1. Easy Wood Tools Ci4 Carbide Cutter - Diamond
Total:
£2,436.92 £2,030.77
The Ci4 solid carbide diamond shaped tip is 9.6mm wide. It fits the Easy Start Easy Detailer, Mini Easy Detailer, and Mid-Size Easy Detailer, Full Size Easy Detailer and Pro Easy Detailer.
​The standard carbide cutters provide a neutral rake, which is the angle of a cutter relative to its cutting surface. These cutters start sharp and stay sharper longer to reduce catches and blowouts.
​When one portion of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.
  • Optimum grade of carbide, long lasting cutting edge
  • Proprietary grinding for the sharpest edge possible.
  • Precision ground finish
  • Easy Wood Tools tips are 100% made in the USA
