Easy Wood Tools Ci6-R1 Carbide Cutter 1" Radius
- Fits the Micro Easy Rougher
- 9.6mm square, solid carbide
- Slightly curved edges minimise the risk of a catch
- Optimum grade of carbide, long lasting cutting edge
The Ci6-R1 solid carbide tip is 9.6mm square. It fits the Micro Easy Rougher.
Each of the four edges is slightly curved with a radius of 1", hence the R1 suffix. The radius along the edge, minimises the risk of a catch from a sharp corner when moving the chisel from side-to-side.
The standard carbide tips provide a neutral rake, which is the angle of a cutter relative to its cutting surface. These cutters start sharp and stay sharper longer to reduce catches and blowouts.
When one side of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.
- Proprietary grinding for the sharpest edge possible.
- Precision ground finish
- Easy Wood Tools tips are 100% made in the USA
