From £139.98 £116.65
In Stock
- get it Saturday 23rd Sep, order within and choose Premium delivery. Delivery info
  • Ideal for spindles, table legs, large bowls, platters etc
  • Detailer for small coves, beads, and other fine details
  • No need to sharpen; simply rotate cutter to a fresh edge
Customers Also Bought
Easy to turn. Easy to own.
100% Made in America
Easy Wood Tools were the first company to develop replaceable carbide-tipped turning tools for professional woodturners and hobbyists back in 2008. The company makes the tools in their headquarters in Kentucky and the carbide tips in their own manufacturing plant in Illinois. This gives them complete control over development and quality of their products.
What makes them 'Easy'?
Square section bar
This unique design ensures the tool sits flat and steady on the tool rest, making it safer and easier to use. No need to learn specific bevels or cutting angles to make your cuts, simply hold the tool and move it left or right to rough out, smooth or create coves or beads.
No need to sharpen
Each tool features a carbide cutter which keeps an edge at least ten times longer than HSS (High Speed Steel). When an edge eventually becomes dull, simply slacken the fixing screw, turn to a fresh edge and go again.
Pick your project
Easy Wood Tools offer a range of different size tools to ensure you have a tool perfect for your project. Within each range the tools have different coloured handles for quick and easy recognition.
Use these tools to turn dry or green wood; they equally work well on very hard woods, acrylics and resins. The negative rake tips work particularly well on acrylics, polyester and resins, and produce a smooth finish on timber.
  1. Easy Wood Tools Full-Size EASY DETAILER™
Total:
£310.82 £259.02
Easy Wood Full-Size Easy Tools are ideal when it comes to turning spindles, table legs, large bowls and other similar projects. He longer handle offers greater control when working on larger projects
Use the Easy Wood Full-Size Easy Detailer to create coves, beads, and other fine details. It comes fitted with a diamond shaped tip and includes a hex key for the mounting screw. The 406mm long handle is American Maple with a copper ferrule for strength (the tools have different coloured handles for easy recognition). The 12.7mm square section bar ensures the tool sits flat and steady on the tool rest. With the tool parallel to the floor and cutting at centre height the risk of catches and snatches is virtually eliminated. You don’t need to sharpen these tools. When an edge becomes dull you simply slacken the fixing screw and turn to a fresh edge. Easy Wood Tools’ carbide keeps an edge many, many times longer than HSS. These tools can be used to turn dry or green wood and acrylics.
Overall length of 622mm. The shaft is engraved with the corresponding carbide cutter reference number.
  • Solid carbide tip keeps an edge many, many times longer than HSS
  • Use to turn dry or green wood, acrylics and resin
  • 12.7mm square section bar ensures the tool sits flat and steady
  • American Maple handle with copper ferrule for strength
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTickA tick symbolTrade AccountSaving tag iconDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
    5 1
