Easy Wood Tools Mid-Size Easy Hollowing™ Set 3-Piece
109210
From ÂŁ399.98 ÂŁ333.32
  5. Half Star
2 Reviews
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 20th May
  • Set of 3 Hollowers, hollow forms are as easy as 1, 2, 3
  • Carbide cutting tips keep an edge many times longer than HSS
  • Rectangular section shafts improve stability and minimise chatter
  • No need to sharpen; simply rotate cutter to a fresh edge
  • American Maple handle with copper ferrule for strength
Go-to tools for any turner
A versatile set of tools for a range of turning projects. Whether it bowls, platters or boxes, the Easy Wood Mid-Size range is the perfect go-to tool to keep your turning on track
  • Handles are made from one-of-a-kind grained American Maple and feature a copper ferrule for strength
  • All tools come with a fresh standard carbide cutter installed, and a hex key that fits the mounting screw
  • The range features three cutting types with colour coded handles to make your turning easy from start to finish
Mid-Size Easy Rougher
Remove bulk material quickly and efficiently.
Mid-Size Easy Finisher
For creating curves and for final shaping.
Mid-Size Easy Detailer
Create fine details such as small coves and beads.
Mid-Size Micro Easy Detailer
For precision details - micro coves, beads, and finer details.
Why buy?
All tools come with a carbide cutter and hex key. These cutters retain their edge with no need for regular resharpening. When one edge does dull, simply flip the cutter and finally replace when needed. A range of optional cutters and replacement cutters are available too.
Easy to use
All Easy Wood Tools are held flat to the tool rest and parallel to the floor making them much easier to use than traditional tools.
Never sharpen again!
The premium grade carbide tipped cutters last at least ten times longer than HSS (High Speed Steel) before dulling. Meaning you can turn time and time again, with no need to sharpen.
Replace your cutters
When your edge finally dulls, simply replace it. All tool shafts are engraved with the corresponding engraved cutter number to make replacing cutters simple. See the range of cutters
Quality from end to tip
All carbide cutters feature the best grade carbide for lasting sharpness and a precision grind for a smooth and optimum edge for your turning.
  1. Easy Wood Tools Mid-Size Easy Hollowing™ Set 3-Piece
Total:
ÂŁ500.72 ÂŁ417.27
Easy Wood Tools Easy Hollowers are designed to make turning hollow forms easier and safer and confidently. This set of all three will give you access from just-under-the-rim to deep unseen cavities. Hollowing is as Easy as 1 - 2 - 3.
The Mid-size Easy Hollower #1 is used to remove the bulk of the material from the middle of the hollow form or from the centre of medium to large bowls. It has a 12.7mm square section shaft providing stability when sitting on your lathe’s tool rest.
The #2 Mid-size Easy Hollower has a gently curved shaft allowing you to begin hollowing to the side and start undercutting.
The Mid-size #3 Easy Hollower has a pronounced curve, which allows you greater access when undercutting deep inside the hollow form. Both the #2 and #3 Hollowers have 9.5mm deep by 19mm wide rectangular section shafts providing excellent stability and giving a chatter-free reach of 100mm.
Easy Wood Tools’ replaceable carbide cutting tips keep an edge many, many times longer than HSS. When the edge eventually dulls; simply slacken the fixing screw and turn to a fresh edge.
The 355mm long handles are straight grained American Maple, with copper ferrules for strength. Their overall length is 572mm.
4.50 2
