Easy Wood Tools Pro EASY ROUGHERâ„¢
109308
From £149.98 £124.98
2 Reviews
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Thursday 26th Jun
  • Substantial tools for larger projects with long handles for full control
  • Rougher removes material quickly, cleanly and efficiently
  • No need to sharpen; simply rotate cutter to a fresh edge
  • Solid carbide tip keeps an edge many, many times longer than HSS
  • Use to turn dry or green wood, acrylics and resin
  • 12.7mm square section bar ensures the tool sits flat and steady
  • American Maple handle with copper ferrule for strength
Solid and substantial
The largest tools from Easy Wood Tools, with a handle length of 20-inches, the Pro range can tackle the biggest of projects with ease.
  • Handles are made from one-of-a-kind grained American Hickory and feature a copper ferrule for strength
  • All tools come with a fresh standard carbide cutter installed, and a hex key that fits the mounting screw
  • The range features three cutting types with colour coded handles to make your turning easy from start to finish
Pro Easy Rougher
Remove bulk material quickly and efficiently.
Pro Easy Finisher
For creating curves and for final shaping.
Pro Easy Detailer
For precision details - micro coves, beads, and finer details.
Why buy?
All tools come with a carbide cutter and hex key. These cutters retain their edge with no need for regular resharpening. When one edge does dull, simply flip the cutter and finally replace when needed. A range of optional cutters and replacement cutters are available too.
Easy to use
All Easy Wood Tools are held flat to the tool rest and parallel to the floor making them much easier to use than traditional tools.
Never sharpen again!
The premium grade carbide tipped cutters last at least ten times longer than HSS (High Speed Steel) before dulling. Meaning you can turn time and time again, with no need to sharpen.
Replace your cutters
When your edge finally dulls, simply replace it. All tool shafts are engraved with the corresponding engraved cutter number to make replacing cutters simple. See the range of cutters
Quality from end to tip
All carbide cutters feature the best grade carbide for lasting sharpness and a precision grind for a smooth and optimum edge for your turning.
  1. Easy Wood Tools Pro EASY ROUGHER™
Total:
£383.22 £319.35
Easy Wood Pro Easy Tools are the largest tools in the Easy Wood range. These are solid and substantial tools for large projects and make turning easy all day long. from start to finish.
Use the Easy Wood Pro Easy Rougher removes material quickly, cleanly and efficiently. It comes fitted with a square tip with a slight (100mm) radius on each edge and includes a hex key for the mounting screw. The 508mm long handle is American Hickory with a copper ferrule for strength (the tools have different coloured handles for easy recognition). The 12.7mm square section bar ensures the tool sits flat and steady on the tool rest. With the tool parallel to the floor and cutting at centre height the risk of catches and snatches is virtually eliminated. You don’t need to sharpen these tools. When an edge becomes dull you simply slacken the fixing screw and turn to a fresh edge. Easy Wood Tools’ carbide keeps an edge many, many times longer than HSS. These tools can be used to turn dry or green wood and acrylics.
Overall length of 724mm. The shaft is engraved with the corresponding carbide cutter reference number.
5.00 2
