EcoPoxy GloPoxy Kit
- Bright glow with extended glow in the dark
- Light absorption and release processes can be repeated endlessly
- Any light source will charge GloPoxy
Customers Also Bought
EcoPoxy offer natural bio-based epoxies that are socially responsible. Their non-toxic products deliver environmentally friendly solutions that can be used to create, build and beautify your projects. Suitable for an array of crafts, the range of innovative epoxies will create natural and versatile surfaces which are truly unique and bespoke to you.
The GloPoxy is a glow-in-the-dark epoxy made with high-grade photo-luminescent ingredients that make sure your epoxy glows as bright as it can for as long as it can. The formula absorbs light as energy and releases this energy when placed in the dark. It can glow for hours and contains no impurities that interfere with its glow. Durable, UV stable and resistant to chemicals, water and abrasion, you can use GloPoxy on virtually any surface either indoors or outdoors.
GloPoxy is recognised for safety applications in complete darkness or emergency lighting conditions. Safety depends upon occupants being able to evacuate dark interior spaces with markings for floor level directional exit pathways, landings, stairs, handrails and emergency exits. Resin Part A and Hardener Part B supplied together 200g.
- Low odour, no VOC’s, non-toxic
- UV stable, durable, chemical, water and abrasion resistant
- Excellent hardness and wear resistance
