The Einhell TE-OS 18/150 Li Solo Power X-Change Sander utilises 'Extreme Fix' hook & loop fastening so that the abrasive paper can be changed in seconds and then deliver a high rate of material removal due to low slippage.
For clean, practically dust-free working, there is a dust collection box with active dust extraction. The collection box can be replaced by an attachment to a vacuum cleaner, drawing off the dust directly, this way the air remains clean and the abrasive paper sharp. The rugged aluminium fan impeller ensures that the sander runs smoothly to deliver optimum results.
Supplied with 6 x Abrasive Sheets for wood so you can begin work immediately.
Part of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required.
Supplied as body only (no battery or charger).
Specifications:
Oscillating Speed: 24,000/min.
Oscillating Diameter: 1.6mm.
Sanding Paper Size: 150 x 150 x 100mm.
Weight: 0.748kg (without battery).
Please note; with the dust box fitted only 1.5Ah, 2.6Ah and Plus batteries can be used. Standard Power X (PXC) batteries will need to be used without the dust box fitted.
Einhell 3 Year Warranty on Tools & Batteries + 10 Year on Brushless Motor Warranty
(Registration Required)
