Einhell TE-PS 165 Plunge Saw 1,200W 230V
113544
From £99.98 £83.32
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • Online exclusive
  • Tool-free depth & tilt angle adjustment for precise cuts at 45° to 90°
  • Parallel stop & blade lock ensure straight results & easy blade changes
  • Large handle & vision panel for fatigue-free operation & improved visibility
  • 4-meter cable offers an extended radius of movement
  • Vacuum extractor adaptor keeps the workspace clean
The Einhell TE-PS 165 Plunge Saw is easy to use, sawing depth and tilt angle adjustment are performed without tools. Enables precise cuts to be made at tilt angles of 45° to 90°. Straight results are assured by the parallel stop and a blade lock makes it easy to change the saw blade.
A large handle helps prevent fatigue when working. Whilst the vision panel provides a better view of the cutting area. Fitted with a four meter cable for an extra large radius of operation. There is also a handy vacuum extractor adaptor that helps you to keep the work space clean whilst you work.
Supplied with: 1 x High Quality HW/TCT Saw Blade 165 x 20mm x 48T.
Guide rail system is available separately.
Specifications:
Input Power: 1,200W.
No Load Speed: 5,200/min.
Depth of Cut: @90º 56mm, @45º 42mm.
Blade: 165 x 20mm Bore.
Weight: 4.75kg.
Warranty Einhell 3 Year Warranty on Tools & Batteries + 10 Year on Brushless Motor Warranty (Registration Required)
