Einhell TP-AG 18/125 CE Q Li Pro Angle Grinder 18V (Body Only)
- Online exclusive
- Cordless brushless motor delivering 900W-equivalent performance
- Speed control electronics ensure consistent power & adaptability
- Quick-release nut for effortless disc changes without tools
- Adjustable disc guard & dual-position handle for flexibility
- Integrated dust screen & overload protection for durability & safety
- Part of the Power X-Change series of tools
- 3 Year Einhell Warranty (registration required)
The Einhell TP-AG 18/125 CE Q Li-Solo Pro Angle Grinder is a practical tool for grinding, cutting, roughing and polishing. Powered by a powerful brushless motor. Brushless motors are more efficient, more powerful and more durable than brush motors. What's more, no maintenance whatsoever is required with brushless motors. Thanks to its powerful motor, the cordless angle grinder delivers the same power as a corresponding corded device with 900W.
It can be flexibly adapted to the respective material and the various applications via speed control. Continuous speed electronics ensure consistent performance without loss of speed, even under high loads.
The quick-release nut makes it possible to quickly change the cutting disc without tools. Its additional handle can be mounted in two positions and features softgrip surfaces for comfortable handling. Maximum flexibility is offered by the disc guard with quick adjustment, which can be adapted to the respective working position.
An integrated dust screen protects the interior of the device from dirt and, in combination with the intelligent air ducting, increases the service life. For cleaning, the grille can be easily removed. An overload protection prevents overheating damage and soft start and restart protection ensure high safety during work.
Supplied without cutting and grinding wheels (sold separately).
Part of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required
Powered by Lithium-ion rechargeable batteries with a battery management system for a long life.
Supplied as body only (no battery or charger).
Specifications:
No Load Speed: 3,000-10,500min.
Disc Diameter: 125mm.
Weight: 1.7kg.
