The Einhell TP-CD 18/80 Li-i BL Power X-Change Combi Drill is powered by the Einhell PurePOWER brushless motor. This brushless motor offers more power and a longer running time than conventional carbon brush motors. After registering online, the brushless motor comes with a 10-year warranty. The impact drilling function is very useful when working with difficult materials such as stone or concrete.
In addition, the impact drill has a 2-speed gearbox for powerful screwing and fast impact drilling with 8000 impacts per minute in the 1st gear and up to 28,800 impacts per minute in 2nd gear. In this case, the torque-slip clutch prevents the screws from being overtightened. The hard torque of 80 Nm is adjustable over 20 torque levels. With the help of the infinitely adjustable speed electronics, application - and material - appropriate working is possible.
The quick-stop function and the single-sleeve 13 mm quick-release chuck made of metal with locking function enable a quick and easy tool change. Users' joints are protected by the auxiliary handle with Softgrip. The LED light provides a good view of the work area even in poor visibility. For safe temporary storage, the impact drill can be attached to the belt with the belt clip.
Part of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required.
Supplied as body only (no battery or charger).
Specifications:
Drill Chuck: Single Sleeve 13mm.
No Load Speed: 0-500/0-1,800/min.
Impact Rate: 0-8,000/0-28,800/bpm.
Max. Torque: 80Nm.
Torque Settings: 22.
Weight: 1.44kg.
Battery Voltage 18 V
Reverse No
Sound Power Level LwA [Uncertainty K] 98.7 dB(A) [5.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Chuck Capacity 13 mm
Sound Pressure Level LpA [Uncertainty K] 87.7 dB(A) [5.0 dB]
Model TP-CD 18/80 Li-i BL
Drilling Speed 0 - 500 rpm 0 - 1,800 rpm
Impact Rate 0 - 8,000 / 0 - 28,800 /min
Nett Weight 1.44kg
Torque 80 Nm
Torque Settings 20 + 1 + 1
Vibration Drilling Concrete [Uncertainty K] 10.15 m/s [1.5 m/s]
Vibration Drilling Metal [Uncertainty K] 2.5 m/s [1.5 m/s]
Warranty Einhell 3 Year Warranty on Tools & Batteries + 10 Year on Brushless Motor Warranty
EAN Barcode 4006825672183
